Updates, storingen e.d.
Re: Updates, storingen e.d.
Update van phpBB 3.1.8 naar 3.1.9
This version is a maintenance release of the 3.1.x branch which fixes various smaller bugs including improper column defaults for new table columns in MSSQL, issues with the updater while using caches that are not file based, as well as duplicate emails being sent by the email queue due to opcache, and attached images not being displayed in the expected order when adding them inline. It also adds support for X-Forwarded headers for upgrading non-SSL connections to SSL and allows extension authors to disable sending headers on Extension pages served via app.php.
New Features
Respect X-Forwarded-Headers for upgrading non-SSL to SSL connection - Proxy's request to upgrade users to using SSL instead of non-SSL communication will be correctly respected (e.g. when using HAproxy). This requires default ports for SSL and can only be used for upgrading from non-SSL to SSL and not to downgrade from SSL to non-SSL.
Disable sending headers - Extension authors can disable sending headers in the page_header() function and the controller helper's render() method
Notable Changes
Q&A fallback to non-default language questions - Q&A will try to fall back to Q&A combos that are not the current or default language if it's enabled and no valid Q&A set for the current or default language are set. If this is not possible, the captcha system will throw an error and prevent registrations without filling out the captcha caused by the invalid setup and misconfiguration.
Notable Bug Fixes
Removed automatic approve of unapproved posts - Editing an unapproved post as a moderator will no longer automatically approve it.
Email queue not cached by opcache - Email queue won't be cached by opcache anymore. This caused issues with dulicate emails.
Correct column default in MSSQL - Database column default will no longer be incorrectly escaped in MSSQL (caused upgrade issues for 3.0.x to 3.1.x)
Modified since for files served with download/file.php - The modified since header was not correctly served
File update when using non-file based cache - Admins updating when using caches like memcache no longer see the comparing files page over and over again when looking at file changes
Attachments display according to the correct BBCode ID - Attachments displayed now correctly correspond to the ones defined by the attachment BBCodes that were added using the frontend
Read more: https://www.phpbb.com/community/viewtop ... &t=2368586
Update van PHPBB 3.1.9 naar 3.1.10
The changes for this version are:
This version is a maintenance and security release of the 3.1.x branch which fixes one trivial security issue and various smaller bugs. The security issue only affects users using no longer supported versions of browsers as well as improperly setup webservers (thanks to Lukas Reschke of Nextcloud for reporting this). The bugfixes address the Q&A captcha logging errors when it was solved, fatal errors when upgrading from 3.0.x in certain cases, and database transactions not being rolled back with incorrect notification settings. Other changes include an improved migrator and hardened form checking in the Admin Control Panel.
New Features
* Check phpBB version constant against config version - Display a warning in the ACP if the version constant (files) does not match the phpbb_config version
* Support extensions in UI tests - UI tests now also support installing extensions and testing their behavior
Notable Changes
* Improved migrator - The migrator will now properly prevent timeouts and infinite loops. It will no longer unexpectedly try to revert update_data() implementations using "if": https://www.phpbb.com/community/viewtop ... &t=2383821
* Dropped support for MySQL versions improperly implementing FULLTEXT support - Some MySQL versions used improper implementations of FULLTEXT support. Versions with correct support are now required: https://github.com/phpbb/phpbb/pull/4426
* Users removed from newly registered group when limit set to 0 posts - Users will now be able to exit the newly registered users group when the limit is set to according to the setting's definition in the ACP.
* Further hardened checking links and form submissions - Added link hashes and form keys to all forms in the ACP that were still relying on global ACP form protections.
Notable Bug Fixes
* Prevent MySQL error when looking at your posts - Wrong column was selected in certain cases.
* Q&A CAPTCHA no longer logs error when solved - A change in 3.1.9 caused the CAPTCHA to log an error even though it was solved.
* Min/max form values no longer preventing update of avatar settings - The newly introduced form validation on the html side will no longer report invalid min/max settings when updating avatar settings.
* Fixed fatal error when upgrading from 3.0.x - Fixed error when upgrading from version with softdelete MOD installed.
* Limit prunes per cron for large forums - Prunes on large forums were not limited. This could cause the prune query to fail at an unspecified point in time and leave topics unpruned.
* Rollback transactions in notifications manager - Fixed issues with not rolled back transactions when using non-existent notification types
Upgrade van phpBB 3.1.9 naar 3.2.0 - na de nodige problemen - gelukt.
Van de ontwikkelaars:
Vandaag is een grote dag voor de gehele phpBB community! Met de hulp van meer dan 100 vrijwilligers is het gelukt om tot een betere en moderne versie van phpBB te komen, phpBB 3.2 Rhea.
phpBB 3.2 bouwt voort op de functieset van phpBB 3.1 Ascreaus, met een hoop verbeteringen voor zowel gebruikers als forumbeheerders. De nieuwe BBCode parser voegt support toe voor Emojis dat veelvuldig gebruikt word op mobiele apparaten en voegt slimmere quotes toe. De nieuwe integratie met Font-Awesome in prosilver geeft kwaliteitsiconen, ook op retina schermen. Daarnaast wordt er gebruik gemaakt van Symfony 2.8 en een verbeterde integratie van Twig. phpBB 3.2 Rhea ondersteund ook PHP 7 & 7.1, welke een geweldige snelheidsboost geven aan phpBB.
Forumbeheerders zullen de compleet herschreven installatie fijn in gebruik vinden, doordat deze het gemakkelijker maakt phpBB te installeren en te updaten. Het is nu ook mogelijk om phpBB te installeren of te updaten via de Command Line Interface, naast de browser.
reCAPTCHA 2.0 is toegevoegd aan phpBB 3.2 om te voorkomen dat spammers een kans maken op je forum. Deze nieuwe manier van spampreventie wordt beschikbaar naast de al aanwezige methodes.
Bekijk voor meer verbeteringen de Rhea Launch pagina op phpBB.com, of bekijk de Features pagina voor een volledige lijst.
De phpBB 3.2: Rhea downloads zijn te vinden op de Downloads pagina. Ook de Nederlandse vertaling kan hier worden gedownload.
De phpBB community heeft de afgelopen jaren hard gewerkt om deze release klaar te maken, en werk aan de volgende versie, phpBB 3.3 Proteus, is al bezig! Om beter om te gaan met community ideeën zal het idea center op phpBB.com in de komende dagen weer beschikbaar komen.
Campertechniek.eu heeft een aantal jaren gedraaid op server 128.140.218.120 met PHP 5.3.16. Omdat phpBB 3.2 alleen draait met PHP 5.4 of hoger, moest het hele forum verhuizen naar 185.27.142.170 waarop PHP 5.6 aanwezig is. Na deze verhuizing bleken er een aantal functies niet meer te werken. Dit heeft een paar dagen puzzelen met zich meegebracht.... :evil:
Als nu de beginpagina vol met kleine icoontjes staat, kijk je naar het opgeslagen beeld in het cache geheugen van je eigen browser. Cache legen en alles zou weer goed moeten draaien. Bij problemen kun je me altijd een PB-tje sturen.
vanhooltje
Bericht door vanhooltje »
nou krijg alleen maar rare dingen en rode rondjes in beeld :WTF:
Ook op Afbeelding
Probeer eens de cache van je browser te legen. Bij Sylvia deed dat de truc (na een dag lang ploeteren). Laat even horen of het gelukt is.
vanhooltje
Inderdaad, chache geleegd en nu werkt het weer :up: :up:
Ook op Afbeelding
Dat was snel opgelost :clap:
Beste,
De server en websites zijn weer normaal bereikbaar.
Ons excuses voor het ongemak.
Met vriendelijke groet,
Erwin
http://www.fxw.nl/
http://helpdesk.fxw.nl
Ticket Details
Ticket ID: TBN-883-42327
Afdeling: Technische helpdesk
Was ie weg dan?? :MrGreen: :MrGreen:
Ja, helemaal dood :surprise:
Geen idee of 't wat te maken heeft met de "aanvallen" die de hele dag in het nieuws zijn geweest. Vermoedelijk had iemand in het datacenter gewoon een stekkertje verkeerd geprikt....
Moeten ze ook niet door stagaires laten doen...
Die aanvallen, sja, het was wel erg toevallig dat net op die dag onze security manager met pensioen ging!
Jeroen_Hanomaf schreef:Moeten ze ook niet door stagaires laten doen...
[emoji3] Da's vast geen toeval...
Verstuurd vanaf mijn LG-K580 met Tapatalk
We noticed that there is a minor issue with the Tapatalk setup in your site that prevents the app from working optimally.
Issues were caused by
● Plugin expired (or too old)
Solution:
https://blog.tapatalk.com/knowledgebase ... solutions/
Download Updated Plugin:
https://www.tapatalk.com/getting_started
Need Help?
Submit a suport ticket by logging into the Site Owner Console on Tapatalk.com. Click the Support button at the upper right corner if the page.
Pls. ensure you update your plug-in before submitting a ticket. In most cases, the update will solve your technical issue.
When submitting a ticket, attaching screenshots will help us to better assist you.
Regards,
Tapatalk Team
Quick and dirty:
Oude Tapatalk mappen van server verwijderd, nieuwe versie als geheel nieuwe klant geïnstalleerd. Niet één foutmelding!
En het werkt. Zie de post hierboven.
Graag feedback van andere Tapatalk-gebruikers. Bedankt!
Arno Z
Bericht door Arno Z »
Het werkt (gelukkig) weer met Tapatalk (althans voor mij).
Fijn. Bedankt voor de melding, Arno!
28 juli 2017
Omdat we door het aantal berichten de opslagruimte van ons hostingpakket aan het overschrijden waren, heb ik een groter (en duurder) pakket moeten nemen. Vandaag is het forum verhuisd naar een andere server. Zo te zien is alles goed verlopen. Als je tegen problemen aanloopt, hoor ik het wel.
De snelheid zou ook iets groter moeten zijn door toepassing van een SSD i.p.v. een hard disk. (In mijn ervaring is het eerder je internetverbinding die de snelheid bepaalt, maar goed....)
Tegelijk heb ik voor een hogere veiligheid een SSL-certificaat aangeschaft. Nadat SSL is geïmplementeerd, zie je in de adresbalk https en niet meer http.
Nadat ik 13 jaar lang zelf de kosten (ca. € 60/jaar voor domeinregistratie en hosting) heb betaald, wil ik nu, vanwege de gestegen kosten, je graag verzoeken om een kleine bijdrage in de kosten van registratie en hosting. Idee: is Campertechniek je een liter dieselolie waard?
Een "donate button" vind je links bovenaan alle forumpagina's.
Op sommige fora zie je dat er verschillende categorieën bezoekers zijn, donateurs en anderen. Donateurs krijgen soms ook bepaalde privileges. Ik heb besloten het niet zo in te richten. We zijn met ons allen met onze hobby bezig en wie ben ik om bepaalde mensen voor te trekken?
johan millenaar
Bericht door johan millenaar »
dag ernst, zeg maar hoe je de bijdrage kan ontvangen
groet
johan
Hoi Johan,
Ik heb een PayPal button op m'n privé-site gezet. Zie de link hierboven.
Groeten uit Niedersachsen!
Eventueel een komma gebruiken in plaats van een punt!
Hi Anton,
ik sta altijd open voor suggesties ter verbetering. Maar.... wáár moet een komma in plaats van een punt?
Hoi Ernst,
Ik heb via PayPal een donatie gedaan, als je het bedrag in vult met een punt in plaats van een komma dan krijg je een foutmelding.
Twee maal dankjewel, Anton.
Ik ga dat bij de button vermelden.
Danny
Bericht door Danny »
Hoi Ernst.
Bij mij werkt de knop "doneren" niet.... Ik probeer het morgen nog eens.
Bedankt voor de melding, Danny!
Er blijkt iets mis te zijn met de DNS-settings. Ga er maandag meteen achteraan.
Zal proberen die button in het forum zelf te verwerken, dat is duidelijker.
Gelukt.
Ik zal de link hierboven aanpassen.
Campertechniek nu beveiligd met SSL-certificaat!
31 juli 2017
Als je niet vanzelf te zien krijgt dat je via een veilige verbinding op het Forum bent aanbeland, kun je (de eerste keer) handmatig in de adresbalk invullen: https://www.campertechniek.eu
Als je via een bladwijzer naar het forum gaat, waar "http://" in staat, moet je dat veranderen in "https://"
Voor vragen en opmerkingen: admin@campertechniek.eu !
