Updates, storingen e.d.
Re: Updates, storingen e.d.
Omdat we voor het inloggen persoonsgegevens opslaan, moeten we voldoen aan de Algemene verordening gegevensbescherming
(AVG, GDPR).
Iedereen die wil inloggen, zal de eerste keer akkoord moeten gaan met onze privacy policy. Verder verandert er weinig.... gelukkig!
(AVG, GDPR).
Vandaag de phpBB software ge-update van 3.2.2 naar 3.2.3
Release Highlights 3.2.3
This page highlights important changes in phpBB 3.2.3
Enhancement
Updated dependencies - Updated dependencies to latest versions, e.g. Symfony, Twig
Extension version check supports newer TLS versions - The extension version check will now also support newer TLS versions [1]
Notable Bug Fixes
Previewing / submitting posts with more than one attachment - Attachments were lost after re-submitting post [2]
Sub-SELECTs in sql_build_query() - The sql_build_query() method had issues was unable to add sub-SELECTs in queries [3]
Multiple issues with migrations added in 3.2.2 - The fix_user_styles and merge_duplicate_bbcodes migrations had multiple issues that prevented successful updates [4][5]
Issues with signature edit in ACP - Mixed function parameters caused the ACP to show PHP warnings [6]
Notable changes
HHVM support dropped - phpBB will no longer support HHVM [7]
More visible links to privacy policy and terms - Links to privacy policy and terms of use are prominently displayed in the footer. Link to privacy policy can be overridden with an event [8]
Updated Symfony and other 3rd party libraries - Symfony and other 3rd party libraries have been updated to their latest versions [9]
Enhancement
Notable Bug Fixes
Notable changes
21 december 2018: de phpBB software ge-update van 3.2.3 naar 3.2.4
We are pleased to announce the release of phpBB 3.2.4 "Bertie's ‘stache". This version is a maintenance and security release of the 3.2.x branch which fixes one security issue and various issues reported in previous versions.
The security issue was discovered with a new exploitation technique called Phar deserialization. An attacker with control over a founder admin account could escalate to remote code execution by abusing PHP’s default unserialization of metadata in Phar files. More information about this technique can be found here.
In order to fix this issue we’ve removed the ability to define absolute paths in the Admin Control Panel. This resulted in the removal of setting the ImageMagick path, so make sure to have the GD image library available instead. A new event to generate thumbnails was added as replacement, so you’re able to write an extension that uses a different image library to generate thumbnails. We would like to thank Simon Scannell and Robin Peraglie of RIPS Technologies for their report and responsible disclosure. The issue has been assigned CVE-2018-19274.
The fixed issues include, among others, compatibility issues with PHP 7.2 and issues with removing users from the newly registered user group more than once.
Among the notable changes are the addition of the list-unsubscribe header to emails sent by phpBB and the ability to reset your password without entering the username.
26 december 2018: de phpBB software ge-update van 3.2.4 naar 3.2.5
We are pleased to announce the release of phpBB 3.2.5 "Bertie's Secret Santa". This version is a maintenance release of the 3.2.x branch which fixes various issues reported in previous versions.
The development team thanks everyone who contributed code to this release: 3Di, rxu, Alec, hubaishan, Dark❶, Jakub Senko, Jim Mossing Holsteyn, Vinny
If you have any questions or comments, we'll be happy to address them in the discussion topic.
18 juli 2019: de phpBB software ge-update van 3.2.5 naar 3.2.6 en van 3.2.6 naar 3.2.7
The fixed issues include, among others, issues with form token validation during login, the inability to change topic types after posting, an issue with viewing private message folders, and potentially incorrectly shortened URL links when using the [url=] BBCode.
Full backwards compatibility for styles released before phpBB 3.2.6 has been introduced, which will enable logins even though these styles have not yet been updated with the latest style changes.
The full list of changes is available in the changelog file within the docs folder contained in the release package. You can find the key highlights of this release on the wiki at https://wiki.phpbb.com/Release_Highlights/3.2.7 and a list of all issues fixed on our tracker at Issues fixed in 3.2.7
1 oktober 2019: de phpBB software ge-update van 3.2.7 naar 3.2.8
There is a new version 3.2.8. It fixes one bug I caught about the same time the extension review team found it that caused digests to fail when a digest was requested to include a table of contents.
Also fixed the Unicode bug found by whocarez. Great analysis! When examining this code I realized it could be made more efficient, so now it loads the post text into a document tree only once.
I removed fancy language file changes that used sprintf() to embed certain dynamic information, mostly out of laziness. I'm sure it can be done the way the extension review team wants but it was more of a challenge than I wanted to take on considering I was using the $display_vars approach to showing fields and help information in the ACP. Laziness and some exasperation with bugs in the migrator in phpBB 3.2.2 also prompted me to remove code that used to work that removed modules for digests left over in the database if the digests mod was installed previously. These modules should be manually removed before installing the extensions using instructions in the README.md to avoid a likely installation error.
6 februari 2020: de phpBB software ge-update van 3.2.8 naar 3.3.0
The new phpBB 3.3 Proteus builds upon 3.2 Rhea and is a big step towards a more modern base while maintaining a clear update path. It is now shipped with Symfony 3.4, Twig 2, and jQuery 3.4. The improvements include, among others, support for Invisible reCAPTCHA, Argon2i and Argon2id password hashing, improved reset password functionality, and minor changes to the UI.
The minimum supported PHP version has been increased to PHP 7.1.3 while support for PHP 7.3 and PHP 7.4 has been added. Fixed security issues in 3.2.9 are part of this release as well.
Voor de liefhebber.
Voor de liefhebber.
April/mei 2021
Bij de upgrade van PHPBB van 3.3.0 naar 3.3.3 is er van alles misgegaan.
Gelukkig is Danny van PHPBBSERVICE.NL er in geslaagd het forum te repareren, zonder dat er ook maar één post verloren is gegaan. Hulde!!!
En passant heeft hij ook versie 3.3.4 geïnstalleerd.
Goed bezig Ernst, fijn dat dit forum nog levend is.
+1 Ik zal de laatste avonturen van onze LT ook nog even posten :)
Graag!
11 november 2021: Update naar phpBB 3.3.5
Dat ging super-gladjes. Was in drie minuten gebeurd.
Bij de introductie, vorige maand:
Zojuist heeft het phpBB team de nieuwe phpBB versies 3.3.5 "Ich bin ein Bertie" uitgebracht. Deze versie is onderhoudsreleases voor de 3.3.x branche.
Met deze release is de compatibiliteit met php8 verbeterd, en diverse issues met betrekking tot upgrading van en converteren naar phpBB opgelost. Er is ook een bug opgelost waarbij onzichtbare UTF-8 tekens gebruikt konden worden in gebruikersnamen, waardoor verwarring kon onstaan tussen gebruikersnamen.
Zoals altijd is de volledige lijst met veranderen te vinden in de changelog bestanden in de docs map van het releasepakket. De highlights hiervan zijn te vinden in de phpBB.com mededeling. Ook een volledige lijst van alle opgeloste problemen is te vinden in de bug tracker.
De pakketten om deze versies te downloaden samen met de Nederlandse vertaling zullen zeer binnenkort op onze Downloads pagina beschikbaar worden. Wanneer dit het geval is zullen wij dat laten weten middels een reactie op dit bericht.
Het phpBB ontwikkelaarsteam (en wij uiteraard ook) willen graag de volgende mensen bedanken die aan deze releases hebben meegeholpen: 3D-I, rxu, Alec, Patrick Webster, Prosk8er, v12mike, Alfredo Ramos, David Colón, Matt Friedman, MichaIng, William Desportes, Paul, toxyy
Blij dat jullie nog dit forum onderhouden aangezien het hier vaak gezelliger is dan in de facebook groepen!
Mercedes 813
Ik doe m'n best. Ik houd in elk geval de techniek up-to-date. Maar... er zijn weinig bezoekers, de laatste tijd. Misschien zijn de "oude busjes" aan het uitsterven. Of misschien zijn alle voorkomende problemen al besproken
Je hebt wel gelijk: op Campertechniek.eu lees je zelden: "Dat is zo, ik heb het gehoord van de neef van m'n buurvrouw." Of: "Dat is zo, zelf gelezen op een website..."
zou zomaar kunnen, ik zie in elk geval zelden meer oude busjes rijden.
En als het er één is, is het vaak een VW Transporter, en daar zijn weer andere fora voor.
Het valt me nu echt op als je nog een DuDo ziet rijden, laat staan een Hanomag...
Ben ik zelf natuurlijk mede-schuldig aan, met m'n 2003 common-rail bus!
Ben niet boos hoor, Jeroen. Met m'n 2014 Ducato. Al zitten er inmiddels een heleboel niet-originele extra's in en op....
- Detlev
We springen echt soms maanden vooruit hier ;)
Busjes nemen niet af hoor, bij die maffe DBBL club blijft het ledenaantal maar groeien, zitten ergens tegen de 2500 aan nu.
Overigens nog steeds niet te besturen die hap.....
Deze oude bus is er nog steeds hoor, maar sins we in friesland wonen gaan we niet zo vaak meer weg. Nog veel te doen aan het huis en daar mijn gezondheid te wensen overlaat (atrose) moet ik het rustig aan doen. En ja veel meldingen zijn er hier ook niet zo veel meer helaas. Tevens veel bezig met mijn modelbouw hobby.
Grt peter.
Grt peter.
Detlev, leuk (voor ze) dat Dubbellucht het zo goed doet. De onderdelenvoorziening zal langzamerhand wel steeds essentiëler worden... En wat dat besturen betreft: ik ben al geweest!
Peter, wat akelig dat de artrose je parten speelt! Is die bovenop de hoofdpijnen gekomen? Vrouwenparochie ligt maar 65 km van Haulerwijk, dus we moeten toch maar een keertje langskomen....
Groeten aan Louise resp. Christl!
Hoi Ernst,
Van de hoofdpijnen (clusters) heb ik gelukkig geen last meer (afkloppen klop klop). Door mijn werk in het verleden ben ik behoorlijk versleten wat nogal wat ongemakken veroorzaakt. Dat ouder worden is het probleem niet, de klachten wel.
Dat langs komen kan maar in overleg a.u.b.
Groet Christl en peter.
Peter, als je in de tussentijd niet op reis gaat, heb je groot gelijk!
Groetjes, ook aan Christl!
13 april 2023: Update van phpBB 32.3.8 naar phpBB 3.3.10
Dat ging alweer super-gladjes. Was in drie minuten gebeurd.
Greetings everyone,
We are pleased to announce the release of phpBB 3.3.10 “The Way of Bertie”. This version is a maintenance release of the 3.3.x branch which improves support for PHP 8.2, and resolves various issues reported in previous versions.
Previous versions of phpBB started showing a “broken image” icon next to the browser’s fallback emoji due to the service of the Emoji Content Delivery Network (CDN) being shut down. In order to resolve this, the emoji CDN has been replaced alongside other fixes which include improved handling of errors while using the Spamhaus blocklist, and proper handling of emojis when adding feedback in the Moderator Control Panel (MCP).
In addition to this, we have improved support for the use of reCAPTCHA for countries where the main domain might not be accessible, and the explanation of the ACP setting for allowing the “usage of third party content delivery networks” has been improved.
Further hardening has been added to the cron redirect to prevent exceptions from being left unhandled.
Thanks to recent changes to the phpBB repository on GitHub, contributing to phpBB has become easier than ever with the support of GitHub Codespaces. Check out our blog post on how to use GitHub Codespaces with phpBB or find out more on GitHub.
The full list of changes is available in the changelog file within the docs folder contained in the release package. You can find the key highlights of this release below and a list of all issues fixed on our tracker at https://tracker.phpbb.com/issues/?filter=16195
The packages can be downloaded from our downloads page.
The development team thanks everyone who contributed code to this release: Patrick Webster, Christian Schnegelberger, LukeWCS, Matt Friedman, SagePtr, wordlesswind
Marc
Development Team Leader
Release highlights
Notable Improvements
Improved support for PHP 8.2: PHPBB3-17056
Close notification dropdown after marking all read: PHPBB3-13291
Improve support for recaptcha domains: PHPBB3-16105
Notable Changes
Update the emoji CDN: PHPBB3-17071
Notable Bugfixes
Error caused by emojis in MCP feedback: PHPBB3-17065
Check for error codes when querying Spamhaus: PHPBB3-17092
phpBB 3.3.10 Release - Event Changes
ACP Template Events
acp_overall_footer_body_after
Placement: overall_footer.html
Added in Release: 3.3.10-RC1
Explanation: Add content before the `</body>` tag but after the $SCRIPTS var, i.e. after the js scripts have been loaded
acp_simple_footer_body_after
Placement: simple_footer.html
Greetings everyone,
Marc
Release highlights
Notable Changes
Notable Bugfixes
ACP Template Events
20 maart 2023
Er eindelijk even voor gaan zitten.... het logo ("Pannenhilfe") is terug!
In de nieuwere versies van phpBB zijn plaatsen en namen van bestanden allemaal anders, dus het was even puzzelen. Blij dat het gelukt is!
Op 9 april 2024 de upgrade naar 3.3.11 opnieuw van a tot z doorgevoerd.
En - lo and behold - de extensie ACP Add user werkt weer.
En met een nieuw geïnstalleerde extensie moet ook het site_logo in de toekomst met een paar klikken hersteld kunnen worden. Dat was altijd úren puzzelen....
