Het zelf registreren door nieuwe bezoekers is momenteel uitgeschakeld (i.v.m. de vele spammers). Je kunt de Admin bereiken via: admin(at)naam-van-dit-forum
Because of the amount of fake registrations you cannot register as a new user yourself. The Admin can be reached as: admin(at)name-of-this-board
Updates, storingen e.d.
Re: Updates, storingen e.d.
Vandaag de phpBB software ge-update van 3.2.2 naar 3.2.3
Release Highlights 3.2.3
This page highlights important changes in phpBB 3.2.3
Enhancement
Updated dependencies - Updated dependencies to latest versions, e.g. Symfony, Twig
Extension version check supports newer TLS versions - The extension version check will now also support newer TLS versions [1]
Notable Bug Fixes
Previewing / submitting posts with more than one attachment - Attachments were lost after re-submitting post [2]
Sub-SELECTs in sql_build_query() - The sql_build_query() method had issues was unable to add sub-SELECTs in queries [3]
Multiple issues with migrations added in 3.2.2 - The fix_user_styles and merge_duplicate_bbcodes migrations had multiple issues that prevented successful updates [4][5]
Issues with signature edit in ACP - Mixed function parameters caused the ACP to show PHP warnings [6]
Notable changes
HHVM support dropped - phpBB will no longer support HHVM [7]
More visible links to privacy policy and terms - Links to privacy policy and terms of use are prominently displayed in the footer. Link to privacy policy can be overridden with an event [8]
Updated Symfony and other 3rd party libraries - Symfony and other 3rd party libraries have been updated to their latest versions [9]
21 december 2018: de phpBB software ge-update van 3.2.3 naar 3.2.4
We are pleased to announce the release of phpBB 3.2.4 "Bertie's ‘stache". This version is a maintenance and security release of the 3.2.x branch which fixes one security issue and various issues reported in previous versions.
The security issue was discovered with a new exploitation technique called Phar deserialization. An attacker with control over a founder admin account could escalate to remote code execution by abusing PHP’s default unserialization of metadata in Phar files. More information about this technique can be found here.
In order to fix this issue we’ve removed the ability to define absolute paths in the Admin Control Panel. This resulted in the removal of setting the ImageMagick path, so make sure to have the GD image library available instead. A new event to generate thumbnails was added as replacement, so you’re able to write an extension that uses a different image library to generate thumbnails. We would like to thank Simon Scannell and Robin Peraglie of RIPS Technologies for their report and responsible disclosure. The issue has been assigned CVE-2018-19274.
The fixed issues include, among others, compatibility issues with PHP 7.2 and issues with removing users from the newly registered user group more than once.
Among the notable changes are the addition of the list-unsubscribe header to emails sent by phpBB and the ability to reset your password without entering the username.
26 december 2018: de phpBB software ge-update van 3.2.4 naar 3.2.5
We are pleased to announce the release of phpBB 3.2.5 "Bertie's Secret Santa". This version is a maintenance release of the 3.2.x branch which fixes various issues reported in previous versions.
The development team thanks everyone who contributed code to this release: 3Di, rxu, Alec, hubaishan, Dark❶, Jakub Senko, Jim Mossing Holsteyn, Vinny
If you have any questions or comments, we'll be happy to address them in the discussion topic.
18 juli 2019: de phpBB software ge-update van 3.2.5 naar 3.2.6 en van 3.2.6 naar 3.2.7
The fixed issues include, among others, issues with form token validation during login, the inability to change topic types after posting, an issue with viewing private message folders, and potentially incorrectly shortened URL links when using the [url=] BBCode.
Full backwards compatibility for styles released before phpBB 3.2.6 has been introduced, which will enable logins even though these styles have not yet been updated with the latest style changes.
The full list of changes is available in the changelog file within the docs folder contained in the release package. You can find the key highlights of this release on the wiki at https://wiki.phpbb.com/Release_Highlights/3.2.7 and a list of all issues fixed on our tracker at Issues fixed in 3.2.7
1 oktober 2019: de phpBB software ge-update van 3.2.7 naar 3.2.8
There is a new version 3.2.8. It fixes one bug I caught about the same time the extension review team found it that caused digests to fail when a digest was requested to include a table of contents.
Also fixed the Unicode bug found by whocarez. Great analysis! When examining this code I realized it could be made more efficient, so now it loads the post text into a document tree only once.
I removed fancy language file changes that used sprintf() to embed certain dynamic information, mostly out of laziness. I'm sure it can be done the way the extension review team wants but it was more of a challenge than I wanted to take on considering I was using the $display_vars approach to showing fields and help information in the ACP. Laziness and some exasperation with bugs in the migrator in phpBB 3.2.2 also prompted me to remove code that used to work that removed modules for digests left over in the database if the digests mod was installed previously. These modules should be manually removed before installing the extensions using instructions in the README.md to avoid a likely installation error.
6 februari 2020: de phpBB software ge-update van 3.2.8 naar 3.3.0
The new phpBB 3.3 Proteus builds upon 3.2 Rhea and is a big step towards a more modern base while maintaining a clear update path. It is now shipped with Symfony 3.4, Twig 2, and jQuery 3.4. The improvements include, among others, support for Invisible reCAPTCHA, Argon2i and Argon2id password hashing, improved reset password functionality, and minor changes to the UI.
The minimum supported PHP version has been increased to PHP 7.1.3 while support for PHP 7.3 and PHP 7.4 has been added. Fixed security issues in 3.2.9 are part of this release as well.
Voor de liefhebber.
April/mei 2021
Bij de upgrade van PHPBB van 3.3.0 naar 3.3.3 is er van alles misgegaan.
Gelukkig is Danny van PHPBBSERVICE.NL er in geslaagd het forum te repareren, zonder dat er ook maar één post verloren is gegaan. Hulde!!!
En passant heeft hij ook versie 3.3.4 geïnstalleerd.
Goed bezig Ernst, fijn dat dit forum nog levend is.
Jeroen_Hanomaf
Bericht door Jeroen_Hanomaf »
+1 Ik zal de laatste avonturen van onze LT ook nog even posten :)
Graag!
