Sorry in English, I have a problem with the hand throttle on my 1986 508d Ambulance in that occasionally maybe 1 in 20 times when I push in or turn it does not stop the engine, any ideas of the problem please someone.
Regards--------kim
508 - Hand throttle problem
Re: Hand throttle problem
Hi,
When you push down the button does the gas rod retracts normally?
You can check if the rods move free otherwise put some grease on the joints, is the spring still on the rod?
Hi Yoni, many thanks for the reply I can feel a strong resistance on the spring so guess that is OK l will try the grease is there a point behind the dash panel that will need grease?
Regards-------Kim
Regards-------Kim
If you look under the hood there is on the right side of the engine a lever that is moved by de hand throttle button mayb that lever is the problem. (stuck)
you can always stop the engine lifting your gas pedal upwards with your foot ;)
Good luck finding the problem!
Cheers
Cheers
Thanks again Yoni much appreciated
Gebruikers op dit forum: Geen geregistreerde gebruikers en 10 gasten
