Kind regards------kim
In theory that is what the switch in question is, push it in power off, push it to let it out power on.Admin schreef:Aan-uitschakelaar is nothing more than on-off switch.
What Paul means is TENSION, but he actually means VOLTAGEpaulv schreef: tention = spanning
Yes it makes a big click when the dash button in question is pushed in or out but is not killing power.GerardM schreef:That switch on the dash controls the main 'mass relay' that is mounted in a little box on the drivers side on the height of your knees when you step into the cabin.
It's the thing that makes big 'click' noise when switched on or off.
Regards,
Dear Kim,Wolvesamongus schreef:the switch on the dash that I am referring to used to kill the power at the ignition, it has power to it because the light comes on at the switch but it is not killing the power to the ignition
So the switch originally served another purpose. Maybe someone with a similar vehicle has a suggestion.or dash instruments as it use to like there is a open circuit because no matter if the switch is in or out the key makes contact when put in.
Many thanks Gerard, I looked on that file 2TH and wiring plan guessed I missed it, now I have a reference I should be OK.GerardM schreef:Back to the original question. The switch is called Batterij-hoofdschakelaar, in the 2TH files I sent it is in the drawing on page 116 as item 51.
Regards,
Yes I think you right the only trouble is there are Severn wires not the five as in the diagram coming out the back of the switch linked to other dashboard switches etc and I can't find the relay.Admin schreef:In that case I'd leave out the relay and the switch completely to prevent the relay coil drawing current and draining your batteries. Most 508s don't have this switch at all.
